ignition timing plate, 3.0l Merc.
Juel-dk
Hi All..
Yesterday i wanted to check the timing on my 1993 3.0L mercruiser, i went out to my boat, warmed it up, shorted the 2 white wires, and took off the kill switch, rigged the timing gun to the engine, and started shooting.. but my timing plate looks like this:
And the manual looks like this:
How should i see what tap, is what degree?
Is my only option to set my engine at TDC, and then mark the timing plate??
Kind regards
Morten
buggiedad_67
Re: ignition timing plate, 3.0l Merc.
look at the manual pic and take a white out and put a mark where tdc is, trun your crank slowly and put a white line where it is then just count up from there each high and low markes are 2 degrees put a white mark at 4 and at 8 then time it, or take a litle sand paper and clean the plate the marks should be there under the dirt
Juel-dk
ok, ill try to sand of the paint.. thanks :D
Ayuh,... Just clean it up,+ you can probably read it....
JustJason
a wire cup brush on the end of a cordless drill or die grinder will probably work better at cleaning that up
