Ignoring user doesn't work
spoilsofwar
I've added a user to my ignore list, which in theory should block all his posts from my view. However, it doesn't seem to do anything. Is this a known issue with the forum? His name is spelled correctly, in fact generated by the user list as you type in a name. Not a huge deal as I can always manually ignore (look the other way), but I'm just wondering what's up with this.
southkogs
Huh ... the only way I can test it is to ignore someone. Hmmmmmmm ... gotta' figure out which MOD goes first :rolleyes:
GA_Boater
iboats_tim
Any thoughts from you guys?
GA_Boater
Ignore me, Stinkie! LOL
I was going to suggest the same type of test. If it works, I can call you names. :eek: But how will you know? :noidea:
MTboatguy
Geeze, I have been a member on her for a number of years and have never ran into anyone I wanted to ignore?
:eek:
southkogs
GA_Boater I set my :spy: alter ego to ignore yours ... but I can't tell that it's done anything. I still see your :spy: alter-ego's posts. :noidea:
GA_Boater
Just in case - You should have a PM from the other guy.
