I'm so upset.
VIP-Soto
Re: I'm so upset.
wow, he rebuilt the carb but didn't even check the timing? I'm glad its running good now, but I wouldn't take it back to him again.
Yeah, I guess. But like you said, I'm just happy the problem is fixed!
proxyx
Banned
Re: I'm so upset.
Good to hear... btw. have you noticed that every 2-3 posts overheating subject is raised? THat is sooooo... common that not even funny, that's why makes me believe that heat itself not a primary issue... usually something else. Glad you fixed it. You like the boat now? No regrets?
Re: I'm so upset.
You do realize that the timing was not your overheating issue...if you ever had one. It is very normal for the two risers to have quite a difference in temperature. The reason is that the thermostat housing cannot regulate the amount of water sent to each manifold/riser.
I would still replace the impeller if you have no idea how old it is.
proxyx
Banned
Re: I'm so upset.
Enjoy... you were "so upset...". Relax. Use sunscreen.
swcolorado
Re: I'm so upset.
Here's an easy thing to check. Pull off the hoses at your thermostat housing and look inside with a flashlight. Look for black rubber pieces. I had the exact problem you're describing. Port exhaust manifold at 200F; starboard at 160F.
Turned out to be old impeller pieces blocking water flow from the impeller to the thermostat housing (and bypass lines).
