Impeller replacement, 96 6hp
voodoo
I have done it on my 65, any tricks, shifter removal?
sloopy
Re: Impeller replacement, 96 6hp
All you have to do is put the drive shaft in forward gear (it will make it easier to work on when you have the LU in a vise) There is no shift linkage to remove.<br />There are only three bolts holding the LU on, two of them are located next to the zinc (replace it) which is forward of the water discharge/intake port. The third bolt is located in the very front in-front of the shift rod above the anti-spray fin.
voodoo
Spot on advice.<br />Thanks
