In reverse It jumps in and out of gear 1975 iL6 150 H.P.Merc.
timmathis
It is poping in and out of gear going backwards only. Could this just be in cable adjustment? If so how do you set it up? If not what do I need to check? It is A 1975 Merc Inline 1500 150H.P.ob<br />Thanks, Tim
timmathis
Re: In reverse It jumps in and out of gear 1975 iL6 150 H.P.Merc.
Bump
Tim, The gears on that motor will "click" into F-N-R. I would disconnect the gearshift cable at the motor, put the LU and control into Reverse, and see where the barrel adjuster is set. Perhaps it is a combination of a worn gearcase and/or control and a misadjusted cable.
Clams Canino
Exactly.... try disconnecting the cable and seeing where it sits in the adjustment range. You might be able to re-set it to do verse OK. Don't run it like that or reverse WILL go away forever.<br /><br />-W
timmathis
O.K.Thanks,I will give it A try. See ya. Tim
