in the process of changing out my 5.0 merc. vortec for a 5.7 vortec truck engine
alex3012red
Ive went thru a lot of post on differences, i think i got it, my question is does the 5.0 cam work on the 5.7, both are vortec, just thought i asked, since iam taking the heads out to change the gasket. i can do the cam if it works. thanks in advance
depends....
what vintage 5.0..... what vintage 5.7
if both are flat tappet..... your good to go
if both are roller cams..... your good to go
in addition to your head gaskets, dont forget the core plugs need to be brass or stainless
aimlow
A 5.0 and a 5.7 MAY use the same cam. A 5.7 can use a slightly lumpier cam than a 5.0 because of the engine displacement. The heads are definitely different. Check vortec heads for cracks!
achris
More fish than mountain goat
depends....
Merc have always used the same cam in both 5 and 5.7 engines (with Scott's qualifier)...
But if you're using a truck engine, it's cam should be fine...
Chris...
