Inexpensive Amphenol connector crimper?
Klink
Can someone recommend a specific model of Amphenol connector crimpers for pre-2000 Johnson Evinrude engines? Something under $35?
$35 is cheap. A deutsch crimp tool is $280
Klink
vise-grips, used carefully.
Excellent, I wasn't expecting that answer. For as infrequently as I'll be using it, that's exactly what I needed to hear. Thanks.
Klink
Any ideas for the Amphenol Insertion and Pin Removal tools? I used a wire for the Socket Removal tool. Those are the three tools that sell for like $80.
oldboat1
got a cheap idea there too! I use the head of a finishing nail for removal (has a dimple in it to help center on the pin). :)
A needle nosed pliers seems to work for insertion of the pin, maybe with a little WD40 to assist.
Klink
Yes, the finishing nail has the dimple, good one for the pin. The insertion tool seems to just be a tube cut in half, will try the needle nose.
Thanks for the advices!
you can get the deutsch tools, they are plastic, however they generally break. the Amphenal tools at 80 are worth the money.
Klink
Klink
Here's the non-ratcheting crimper.
