Info on Anodes
Texasmark
Re: Info on Anodes
Zinc seems to be the ideal lightweight sacrificial element. Looks to me like you have the A-Z of sacrificial elements.
If anyone can improve on this combination, let them "speak up now or forever hold their piece" ??????? Piece of what ......:%
Mark
crazy charlie
Re: Info on Anodes
I would get a skeg zinc with a fin instead of a flat one.Way more protection with a fin .
Texasmark
Re: Info on Anodes
Well Loco, 8) if you are talking about the trim tab, there is just as much Zinc in the other parts or more....which weren't there for 50 years, than in the trim tab....and back in the old days, there was no Zinc on the bottom of the transom bracket.
Mark
BrianS.
Re: Info on Anodes
Just wanted to make sure I was grabbing the right one for saltwater.
fstbttms
Re: Info on Anodes
Maybe too late to help, but it's zinc anodes for saltwater and magnesium anodes for freshwater.
Texasmark
Re: Info on Anodes
Learn something every day......say what? Never heard of Magnesium sacrificial anodes. But that's not to say that I missed it. d:)
Mark
xtraham
Re: Info on Anodes
Galvanic corrosion occurs when there is a dissimilar metal in contact with the magnesium casting and there is an electrolyte present (such as salt water). There is no issue with interior components but for body, chassis or power-train castings there is a likelihood that galvanic corrosion protection will be required. The approach is to isolate the dissimilar metals either by coating one of the components or using an isolating material as a washer to eliminate the galvanic effect.
fstbttms
Re: Info on Anodes
Texasmark
Re: Info on Anodes
Well get a load of that would you. I had a mercruiser once but didn't have all those babies on it. Course I left salt water 36 years ago so a lot has changed.
Eating crow, yield to the pressure, sorry for the ignorance, man enough to apologize for my stupidity. 8)
And yes I am aware of dissimilar metals, electrolysis, and galvanic corrosion on dissimilar metals especially when they are not in the same group.
But magnesium housings on outboards/outdrives? Who uses that? Thought they were all aluminum (maybe with some copper in it like Mercs XK7 or whatever it is).
Mark
