Initial settings for idle adjustment screws
lindb40530
I have a 1984 OMC With a chevy 305 and a 4 barrel Rochester Quadrajet carbuerator. Can anyone help me with how many turns out I should be after seating the screws for my intitial adjustment. <br /><br />Or, if anyone knows where I might go to find that information. Boat runs like a champ I just have an idling problem.....<br /><br />Thanks....
Re: Initial settings for idle adjustment screws
A turn, to a turn,+ 1/2 will get it running........
prockvoan
Bondo,I had check out that link,when it says to adjust the "air screw" ,are they talking about the screw that adjusts on the throttle linkage?
kwoolard
I think they are referring to the idle adjustment stop screw as you stated on the throttle linkage.
