Inline fuel filter
Ronald1
I'm thinking about putting an automotive in-line fuel filter on my outboard's fuel line. I use portable tanks. Is there any reason this would be a bad idea? To much restiction maybe? Would it be best to put it before or after the primer bulb? I just aquired some old metal fuel tanks and want to play it safe. Thanks
ZmOz
Re: Inline fuel filter
I just used a standard automotive clear plastic inline filter on my outboard...worked fine. I don't think it really matters whether it's before or after the primer.
Solittle
The in-line filters work just fine. Make sure that the filter is the correct one for the diameter fuel line that you have. One thing about the in-line filters. They will filter out the crud but not water. You best bet is a filter that traps the crud but also separates out the water. They look like automotive oil filters and are the best way to go in my opinion.
Ronald1
Thanks for the replies. I was worried about an outboards fuel pump being able to suck premix through a filter (Evinrude 35 and 60).
TOHATSU GURU
Some automotive 4- cycle filters will NOT work on a pre-mix outboard due to the filter element screening out the oil.
Ronald1
Elvin, Answers like yours are EXACTLY the reason why I asked the question. Thanks!
Elvin, and idea or specifics on these filters that will screen out the oil.<br /><br />Answers like yours only make me wonder if I'm using the right stuff. !! :) <br /><br />Any info appreciated.
