Instrument Lables
BeenThere
Looking to recondition/paint my instrument panel this winter. It is currently flat black with the lables written in white above the switches. I would like to powdercoat coat the the panel and of course reapply some lables. But from I've seen at the local boat stores they are just cheap peel-off stick-ons. Does anyone have any suggestions on what I could use. Also do they make powdercoat in flat black?<br /><br />Thanks<br />Don
Northern Eclipse
Re: Instrument Lables
I relabelled my dash with peel and stick I bought from a Crafts store they have been stuck now for 4 or 5 years and still look good.
Got a trophy supply house or a place that engraves awards in your area? You can have small hard plastic labels engraved (you know like a name plate on a uniform) or get the brass award plates engraved. They would outlast any of the peel and stick ones.<br /><br />Bob
18rabbit
Engraved plastic labels like Bob_VT is talking about are readily available at boating stores like West Marine or Boast US for 99-cents/each. May or may not be cheaper than a trophy store, but I like the trophy store engraving idea a lot! You can customize. The plastic labels from WM are standard names only; port, starboard, fog, overboard, sinking…<br /><br /> http://mastercatalog04.westmarine.com/0669.asp
