insulating older mobile home
FSHKPR
Ensign
Hello, just wondering if anybody has expierence with updating an older mobile home. i bought this about 5 or 6 years ago and it sits on 21/2 nicely wooded acreas. right now we use it as a vacation weekend cottage. and we dont use it alot all winter so we just drain the water and only turn on the heat when we come up for a weekend. well two weeks ago the furnace died on me. so now comes the question do i spend 1500 or 2000 on a new furnace or do i just replace the whole trailer. it is a 14 x 70 and is in really great shape. the only problem is it is older and is hard to keep heated. and eventually we would like to retire there and live in it all winter. my feeling if its doable is to do a little at a time, start with the front of the trailer replace all windows with good energy effiecient windows build the outside out to match new windows and add insulation to outside and then reside, with vinyl siding. this way i do not have a 80 thousand dollar bill, all at once and the project could actually be spread out over 4 or 5 years making it more affordable. has anyone done this and do you have any suggestions? or should just I bite the bullet and replace the whole thing in a few years?
Re: insulating older mobile home
I have replaced windows, I have replaced siding and insulation, I have built a house around one. All are viable, it just depends on what you want to do. If you are looking at the mobile home as a perminant fixture, then, as you said, start studding out one side at a time. You can basically just build all around the existing structure. You can attach a new base plate to the floor to handle the improved studding, or you can start from the ground up and enclose the whole thing, giving you an insulated crawl space under the trailer. Be creative! Have fun!
thurps
If it were me, I would look around for a newer repo. You can probably pick one up cheaper than you can refurbish an old one. Don't forget to figure in the removal or demolition of the old one. With that amount of acreage you could gut the old one and turn it into a shop or storage.
