Intake Manifold Gasket
Shredhead
Could someone tell me if my intake manifold gasket was leaking, would that allow water to get into my oil. I am still trying to track down the problem, I guess I am just praying that it is not a cracked block. Any advice or help would be greatly appreciated. Thanks
Re: Intake Manifold Gasket
Ayuh,... Pretty hard to say, without knowing What the motor is...
To find the leak, isolate,+ pressurize the block's cooling passages with Air...
You'll Hear the leak, then follow the sound...
