Is it safe to cap off connector assy. ( on the lower unit ) ?
Shallowman
Can i just cap it off since the lower unit is off instead of getting the connector assy. since it was not used anyways ?
Shallowman
Re: Is it safe to cap off connector assy. ( on the lower unit ) ?
Do i need to cap this off , or just leave open ? Iam wanting to get the lower unit back on .
Alumarine
I doubt if anyone knows what you are talking about.
Silvertip
What connector? We can't see your boat and don't know if you are talking about an electrical connector, water connector, or fuel connector.
Faztbullet
Its the speedo and just leave it open as if capped off water can be trapped in it and freeze.
Shallowman
Sorry , it is the speedo one . When i took off the lower unit ( had to use wedges ) it got smashed . Checked a couple dealer here fri and sat. none had the connector in stock and wanted to bolt lower unit back on to see if new water pump assembly works .
