Is my motor sitting to low?
TnTommy
I've seen a lot of post about how the top of lower unit should be even with the bottom of transom is my motor too low? It's in the top hole so I could raise it?
Maybe...is that a false hollow bottom? Anti cavitation plate should be even with the bottom of your motor is clamped to the transom, higher if it's on an offshore bracket.
TnTommy
I believe it is a hollow bottom
Pontoon boats are different;-----Test run and post what happens.----Or why the concern?
You need to have someone hanging over the Transom to get a Pic of what it looks like at Top Speed, to determine if the Motor is mounted too Low
jlh3rd
not a false bottom, just the end of the motor pod for a pontoon. Mine is just an open rectangle, no vertical structures.
As mentioned, a pontoon is different. You need to run it and see what the WOT #'s are. Check for ventilation issues and trimming issues, if any, especially when turning at speed.
is this a new to you rig when this this concern suddenly come up ?? any symptoms ... what is the rig doing or not dowing
jlh3rd
point is, it's not a problem until it becomes one. There are basic starting points for rigging/propping a boat but final settings depend on performance...or lack of.
