Is my prop hurting my gas consumption/Speed?
VenoMystic96
My prop is a little chewed up, by the looks of the pic of the condition, is it having a major effect on my gas consumption and speed?
Re: Is my prop hurting my gas consumption/Speed?
More importantly, it could cause damage to the propshaft and seals in the lower unit.
imported_LakeRunner
I've see worse for wear but that looks a little chewed. PropScan will fix it right up! Per cost though it might be better to replace it with a new prop. Stay with AL since it's more forgiving than SS if you strike something. Composites cost less but tend to break easily but they do make for a good backup if you damage your main prop. I use several Vortex props so I can easily switch out if I need more punch for the hole shot or when I am hauling more arse than usual. I keep three onboard ranging from 10 to 15 pitch. The hub cost $25 at Overton's and the props are just under $70 each.
