is the motor to low?
ahicks
Not going to speculate with a shot like that. I would have to see a pic with how the cavitation plate lies compared to the bottom, with the cavitation plate set parallel with the bottom.
WesNewell
Looks too low to me. Running like that, you should be able to see the top of the av plate above the water line for max speed. And It looks to me that all of it is under the water. Just can't tell how far under.
mr gibbs2
motor tucked in on one , the others level any opinions thanks ,a 175 was on the boat before and was mounted at the same height from the top of the transom cap about a inch but the prop always slipped on a moderate turn , so i just started it from there . current prop 14 x23 250 yamaha tachs out 5300
ahicks
Wit a stepped hull/transom like that, about all you can do is experiment. If it's breaking loose too easy when trimmed or turned, you're probably high. If not, you could try to raise it to see what happens. It's likely going to be a compromise....
mr gibbs2
I think up one hole then it will be about the same as the 175 was , since its 140 pounds more then the 175 , it would not push the boat to top rpm but close with a 15x17 but trim response was good . This motor does not feel good when trimmed ( if you know what I mean , like riding on air ) the 175 had1700 hours and a bit tired .
Texasmark
Mercury has transom-engine height dimensions in their Optimax service manual. Basically says that bottom of transom to top rear corner of engine transom bracket to be 20 inches (for a 20" transom mounting midsection) for speeds under about 50. Over 50 it shows comparative data for speed increases with engine jacking above 20". it also shows impact of temperature and altitude on speed for a given rig-setup-load.
Tricky as stated by Mr. Hicks on dead rise transoms. I just bought a well used boat with 12* dead rise at the stern and it came with the engine bolted in the 4th hole down which put it about 2" high on the transom (22").
This boat is capable of about 35-40....on a cold day going with the wind and waves, and going to tell you that having it jacked up is not the right answer. As soon as my lifting eye comes in I am going to drop it down at least 1 hole and maybe 2 (¾-1 ½")and that's guessing as Mr. Hicks said since I have a fair to middlin dead rise at the stern.
I want the Anti-ventilation plate (I used to call it cavitation plate too but was corrected on here...cavitation are the little bubbles forming on the tips of the blades and such) slightly below the hull because I need some bow lift and can't get it with the engine high......the AV plate can't get under the headwater, while trimmed out, to get the lift I want.......prop is a Ballistic SS XL, made for shallow running and bow lift and doing all it can.
For the record, usually I raise the engine (from the standard 20" position) and get better performance and speed, but the rigs were different and responded well to the jacking. As others have said, each rig and it's usage is a unique mechanism for one reason or another.
mr gibbs2
raised it up one hole seems about the same but i think a different prop would get it to ride trimed out a bit better
