Is the stop pin necessary?
skeeterbuilt
If you have a perfectly working tilt and trim for your outboard, is the stop pin necessary? Will anything in the transom get damage if you completely take the stop pin out?
Re: Is the stop pin necessary?
No it is not necessary however it will give you a reference point to the lowest setting. Some boats do not need the motor to be angled towards the transom to reach plain so the pin offers a stop point as a refernce and a timesaver. If you remove the pin keep it aboard just in case the trim ever malfunctions.<br /><br />Bob
