is this a gen 1 or 2 transom assembly
Re: is this a gen 1 or 2 transom assembly
Ayuh,... I don't see anything Broken,...
I'm Guessin' it's an Alpha 1 transom, but you don't show the shift shaft very well, 'n that, along with the remote oil port are the Big differences...
Don't see the oil port either...
It's a Gen II, you can just barely see the reservoir quick disconnect in your first picture.
attachment.php
That is identical to my alpha one gen II to a tee. Just happen to have my outdrive off so I compared
Ayuh,... I must be goin' blind in my old age,...
Or,...
I need a Bigger monitor...
Looks normal from the picture.
