Is this a proper way to decarb an outboard?
Waterrazor
I had read this on-line a long time ago and know i'm ready to decarb my 115 yamaha for the first time and wanted to know what you thought.<br />I read that one could unscrew the fuel filter/water separator and refill it with seafoam. Then start the engine and run until it starts to stall. shut it down, wait 30 min. and start for a second time until it starts to stall again. By the third time most of the smoking should be gone along with the carbon and the seafoam should also be out of the filter! The only advantage that I see is that it will clean the entire fuel system.<br />Does this sound right?
Re: Is this a proper way to decarb an outboard?
SeaFoam is a fuel additive and should be added to the gas tank at the recommended ratio. It works as a fuel system cleaner and should be used as a preventative maintenance procedure.<br /><br />I doubt that your engine will even run on straight SeaFoam.<br /><br />If your intent is to remove the carbon buildup from the cylinders and heads, then a spray decarb solvent product is needed. Buy at least 2 cans of decarb. Some people use one can per cylinder.<br /><br />Run engine at fast idle, with engine running<br />spray liberal amount into each carb,<br />spray some more, spray a larger amount into carbs until engine chokes out and stops,<br />remove spark plugs and spray decarb into each cylinder, install the spark plugs, let it soak for 1 to 12 hours. <br />Start the engine and run at medium throttle, or if at the lake, run it at full throttle. It won't hurt to spray some more through the carbs. Run it for atleast 10 minutes to flush the crud out of your engine.
Waterrazor
Seafoam also comes in a spray for that same purpose!
rickdb1boat
Yes, it does and it's called "Deep Crank". Good stuff, too. Available at NAPA.
Ferrariiwish
Hi,<br />if you can buy a cleaning liquid called "Dipetane" Its brilliant.It can be used in your fuel tank and will decoke your engine as you are using it. It can be used to reduce smoke and works with 2 stroke,4 stroke and diesal.It leaves you carbs in top condition too. Good luck.
Yep, I always forget about the SeaFoam Deep Creep spray because no one in my area carries it. I end up using whatever brand I can find.
captain537
Waterrazor<br />You did not say what year your motor was, I hope it is not oo old if you are just now decarbing for first time.<br />The killer of 2 stroke outbaords is carbon buildup.<br />I use ring free every time I fuel up. Use only Yamalube oil<br />Every 50-75 hours gte your motor warmed up, spray a good decarbing aresol in each cylinder, I use engine tuner. let it soak a minimum of 4 hours, I try to go at least 6-8.<br />Then take your boat for a ride for an hour or so, run at 35-45 hundred rpm so you will loosen and blow out any carbon you have loosened up.<br />When you return, take your plugs out and give them a good cleaning, I replace mine every 150 hours.<br />Learn where you 02 sensor is, take it apart and clean it, it is located next to your starter motor.<br />DO NOT spray any solvents on the sensor, I use a safety pin to get inot the small openings and get the carbon out, go get a 3/4 round cleaning brush like the ones you would use to clean the inside of a copper fitting before soldering it to clean out the bore of the brass housing that the sensor goes in.<br />There is a small stainless steel cylinder in there also it looks like a samll dumbell, use a drill bit by hand to clean the center hole in the dumbell, then I use a fine 600-800 grit crocus cloth to clean the outside.<br />If you keep your 02 sensor clean, de carb every 50-75 hrs, use the right quality oil, use the ring free........you will definitely increase the life expectancy of your powerhead.
Oil Man
An alternative is spend the money on a good quality synthetic oil and spend the time using your boat instead of working on it.<br /><br />Dave
