Is this my problem 90 Yamaha......
staydry
TT started acting up then quit all together.....could be switches, relay or motor...having researched a little bit...disconnected the big green & blue wires from the relay...then connected both directly to a 12v battery...the motor should either lift or retract the engine...reverse the cables and the opposite should occur...in my case nothing happened...double checked with meter to make sure sufficient power from battery to TT motor was adequate....
Don't know if it makes a difference but engine is 2006 4S.....
I guess a new motor for TT will be necessary...??????
99yam40
Re: Is this my problem 90 Yamaha......
bad brushes, armature, winding, or thermal fuse.
you can take apart to see what you find to see if you can repair or just buy a new motor
staydry
I just wanted to verify...it is a bad motor...thanks
