Is this salvageable?
jrtredo
Hi, I bought an old tri-hull with a 1987 70hp Evinrude. The lower unit was cracked, pics below. I found a replacement, but the driveshaft I need is 4 spline and the one I found is 16. Does it look like this one could be welded or is it shot?
thanks
There is more to it then welding that.---It appears to be due to freeze damage and it was full of water.----And welding aluminum castings often distorts them and then on reassembly thing will not fit / go together.----------If you weld it before taking it apart then it may not come apart if you need to !!---Internals are likely rusted ?
flyingscott
Your need to get a lower unit from a 1978 to 1988 model 3 cylinder. The 1989 and later models have different lowers and more splines on the shafts and I believe the casting is different. They don't interchange
jrtredo
thank you for the replies, I will keep looking for a replacement
The fine spline shaft will interchange with the coarse spline and housings pre 88 and later have the same bolt patterns.
emdsapmgr
Once a case cracks like that, it may wind up distorted internally. welding it will just set the internal mis alignment and cause other problems. Scrap it.
jrtredo
OK, in that case I'm going to grab that other lower unit and try to swap the shafts, I have a service manual, looks like I'll have to track down a few OMC special tools, best place to do that on ebay?
Chinewalker
Might be easier and cheaper in the long run just to have a shop do it. They can do seals and such while they're in there, too.
Faztbullet
How many water intake hole on the side??? If 4 its a V-4 unit and wont work.....
