Johnson 140 VRO -88 fouls one plug, runs poor
Ama
Hi all. I need help and fast! Boating season here in Finland is at its best and engine wont run nicely. So, here is whats going on: It started when i was going to plane the boat, suddenly it started to shake and power gone away, one cyl off? At idle it runs and coffs, rpm wont go over 3000 or something like that. Starts fine. When i put new set of plugs same thing. I noticed that #3 cyliders plug went veeery black. Lots of fouling. Tried with oneother same thing in 5 secs. There is also lot of somekind sludge at plughole. #1 cyl was also fouled but not nearly as much and it was wet, #3 was dry. #2 and #4 vere fairly clean but also wet. I tried oneother coil for that badly fouled cyl but no effect. Also noticed that cyls 2 and 4 side is cooler than other side. What is wrong with this thing, please help!!
Bosunsmate
have you checked compression?
Is it a grey type of sludge- sludge normally means a water leak- head gasket, exhaust gasket.....
Bosunsmate
is your primer bulb holding firm with engine off?
have you tried premixing and not using vro?
Ama
It holds like hours, not days. I have not, could vro failure effect to just one or two cylinders?
Bosunsmate
hours is more than enough.
not normally, but if a line blocks up its possible.
have you checked spark?
Test the spark and each lead must be able to jump o gap of 3/8" ( 1 cm ) or more.----What colour stripe is on the orange wires going to the top coils ?
Ama
Wires are #1 blue stripe #2 purple #3 green and #4 is pink
Ama
Ok, problem is fixed or at least it runs fine after disconnecing VRO. Now i would like to know what normal fuel pump i need to replace vro pump?
