Johnson 6hp.fuel pump
dude11
I was needing a fuel pump for my 1976 6hp.Johnson;so I rip thru the internet.Only to find a vast number of different ones for different models & years.Then I find a site that mostly sells parts for older models.Guess what I find out____their all the same up to 25hp.??Prices range from $39 to $104.00. Only difference I can see is orientation of direction of the two inlets;well one's the feed in from tank other is line to carb.and you can flip it around to suit yours.So if your ever in need,,ck it out... Hope this helps someone.Dude11
Very easy to repair these pumps and usually all you need is the diaphragm.---That too is avaiilable by itself for a couple of $$
dude11
Thax guys for the info..I knew they sell kits,but as I said,I needed a new pump.Mine was past rebuilding.
