Johnson 88 SPL identification
sundy58
I have a Johnson 88 SPL, and the ID tag is toast. I have pictures of the powerhead and the cowling.
Any help with identification is appreciated.
I did a cold compression test. The results are not good. It runs, but not well,l and the lower unit seems OK. Is it worth salvaging? I burned 6 gallons of fuel over a 3-hour excursion.
  1. 110
  2. 120
  3. 96
  4. 100​
Likely has the typical broken ring " syndrome "-----All of these suffer from that eventually.----Take the head off to have a look.
