johnson fd-10
Johnson110
Asking Raceone do you know if a fd-10 1956 15 hp cover can be replaced with a 1958 johnson 10 cover? I know you have been around these engines by what you post. Thank you !!
F_R
Never tried it either, but I think the answer is no.
Johnson110
Thanks guys I got this motor it was used in fresh water only the clover will not close all the way on one side. I see on the top where the pin holds the cover together has a crack in the metal, anyhow I am on the search for a cover that will fit it as I want to paint the motor and make it look nice.
Why not repair the cover by welding up the crack
