Johnson Outboards ???
So why should a get a Johnson over a merc or yamaha ? looking at a boat that is currently equipted with a Johnson Ocean runner. Is there any big differences or is it just prefference?
CBGale2
Re: Johnson Outboards ???
Cause they are the best, thats why. :D Its kinda like Ford vs. Chevy, and I left Dodge out on purpose. :DLOL
samo_ott
Cause they are the best (along with Evinrude)... Canadian made!
jonesg
johnson, easy to work on, stay away from the fitch model , make sure the model number doesn't contain an F.
Choosing one brand over another depends on what models you are considering and the availability of service/parts in your area. For example, the 60* V6 carb Johnnys and 60* V6 carb Mercs, are nearly the same displacement and design. Both are fine motors. if you are looking at these, pick the one with the best service+parts availability.
As for other models, usually 3 cylinder 2 cycle motors are better than 2 or 4 cylinder 2 cycle motors, of the same HP. They are lighter than the 4 cylinder models and run smoother than either 2 or 4 cylinder motors. Comparing 2 cylinder motors of different brands, is likely a wash as well.
If you are comparing Optimax with e-TEC, I think it is a toss up. I personnelly like the Optimax design better since you are compressing air vs fuel, but both are fine motors.
restornator
Mercury and Yamaha, and Nissan, and Suzuki, copied a lot of the Johnnyrude technologies and features in the < 70 hp range
