johnson raw water pump leaking 5.7
peejcj8
johnson raw water pump leaking 5.7 part number 10-24228-1.
Same thing happened 7 years ago, water started leaking around the shaft and I replaced it with a new one. Can I just buy a rebuild kit and fix the leak?
Thanks Eric
peejcj8
Re: johnson raw water pump leaking 5.7
cool, got it. Has anyone done this and is it an easy rebuild? Did a quick internet search and could not find info on this exact rebuild and how effective the rebuild is for water leak.
let us know how you do
