Can't really find the info on the googles
J JRegier Petty Officer 2nd Class Joined Aug 17, 2013 Messages 136 May 13, 2014 #1 Can't really find the info on the googles
G greenygreen Seaman Apprentice Joined May 13, 2014 Messages 48 May 13, 2014 #2 Re: Johnson TN-27 flywheel nut torque i am new here but ill try to help you. i have a tn28.. Basic Carburetor Servicing Johnson H and T Series
G greenygreen Seaman Apprentice Joined May 13, 2014 Messages 48 May 13, 2014 #3 Re: Johnson TN-27 flywheel nut torque i think its 40lbs for tn28
G greenygreen Seaman Apprentice Joined May 13, 2014 Messages 48 May 13, 2014 #4 Re: Johnson TN-27 flywheel nut torque your right fr , as usual Last edited: May 14, 2014
jimmbo Supreme Mariner Joined May 24, 2004 Messages 14,289 May 13, 2014 #5 Re: Johnson TN-27 flywheel nut torque The Spec for tn models was 40 - 45 lbs
F F_R Supreme Mariner Joined Jul 7, 2006 Messages 28,226 May 14, 2014 #6 Re: Johnson TN-27 flywheel nut torque greenygreen said: this says 45 lbs for basically the same motor. 3 HP Evinrude Lightwin Ignition System Tune-Up 1952-1967 Click to expand... Just for the record before we steer anybody wrong, 45 Ft/Lbs for a 3hp is wrong. It is supposed to be 30-40 Ft/Lbs. And a 3hp is not the same as a TN anyway. Different size crank tapers and different thread size.
