johnson trim gauge wiring?
mrimike
i purchased a used 98 johnson 200 and the boat i want to put it on has a trim gauge on it. What wires should be connected? Any color code i should look for? The boat the engine came from had no trim gauge. I would think it would have some wiring... would it come out of the trim sending unit? and which goes where on the back of the gauge?
Re: johnson trim gauge wiring?
Mike, My '98 Johnny 150HP V6 service manual shows the trim guage sender wire is white/tan. The Black/tan wire is ground and the green wire attaches to the sender body and is ground as well.
The wires on my motor were painted engine white.
Look for a black lever inside the transom bracket. That will be the operating arm of the sender.
