Just a reminder, check and lube your wheel bearings!
snowman48047
Driving home last night I saw "parts" rolling down the road behind a guy and his wife pulling a really nice 24+' center console something or other boat. About a half mile later I see smoke coming from the right side of the trailer, at the tire. After he turned at a light I decided he wasn't headed for the launch and speed up to get next to him and told him. He pulled into a party store lot and I pulled in behind him. Sure enough that "part" I saw was the bearing cap and there was grease everywhere and it was smoking pretty good. Not sure how long he could have driven on it but...He never even said thanks.
lexer440
Re: Just a reminder, check and lube your wheel bearings!
Just wanted to add a note on this as we are coming to end of boat season for many. The place you get your boat serviced and stored if you do that will not service your trailer unless you ask them to. Many people look after their boat but forget the trailer needs maintenance too.
UncleWillie
It is also better to re-grease the bearings at the end of the season rather than in the spring.
If you do find that the grease has water in it, letting the bearing sit in wet grease all winter is not going to be beneficial.
robert graham
I believe there's plenty of "non-mechanical" type individuals who never check anything....boats, cars, etc....just fill up the tank and let it roll!....and they're not all just women-folks!....
MH Hawker
I will spend about a hour servicing my hubs and repacking them in about 8 weeks, and I pull the rubber plugs and look at them once or twice in season. Love my dexter hubs.
kfa4303
Banned
Good at save and fortunate it didn't cause an accident. I had my entire wheel fall off at the ramp last year myself! Shame the guy was such a putz and didn't say thanks though :/
500dollar744ti
When I bought my used boat, I didn't even attempt to do any work or maintenance on it until the trailer was completely serviced and I had replaced the entire brake system.
zippy83
I'm prety new to this boating stuff, I have a Aluminum 16ft 1995 love and I was wondering what should I look for when I take off the center rubbery peace. Last time (past weekend) I saw that there was prety enough grease in there. How do I check that everything is fine there? What do I need to look out for?
Thanks
Zipp
Can't assume it's purely a bearing problem. I've seen many a smoking hub and missing caps as the result of overheated brakes.
kfa4303
Banned
Thanks
Zipp
Hi Zippy. There are several different styles of trailer wheel bearing and lube systems. It sounds like yours is the type whereby you remove a small rubber cap to gain access to a grease zerk. You can then attach a grease gun and pump lube into the bearings as needed. You'll know the bearings are full when grease comes back out the front around the zerk. However, if you keep pumping and pumping with no effect, then you may have a blow seal on the backside of the bearing. Not to worry you can change the bearings and seals yourself if need be. This link may help.
How to Lube EZ Lube Bearings on a Wells Cargo Trailer - YouTube
zippy83
hi kfa4303
Thanks for the info... That is the exact same system that I have. I will keep this in mind before every trip.
Thank you
Zipp
Rick Stephens
I would suggest that Dexter's EZLube axle grease system is not very useful.
I have been in the trailer business for 25+ years. On anything but a boat trailer, all my 'regular' customers I remove the EZLube Grease zerk and replace the center hole cap with a plain cap. This is to ensure the bearings get a proper cleaning and greasing instead of the totally improper zerk method. On boats I always replace the cap with a Bearing Buddy - more on that later.
Greasing by virtue of the Dexter EZLube zerk fills the hub up with grease and doesn't really grease the bearing until it is full. On any hub that has brakes this is a disaster as you will always end up getting grease into the brake shoes or pads when that full hub gets warm and the grease expands. That is nonsense. And who wants grease all over everything even if you don't have brakes to get gooey?
Proper greasing involves driving the seals out, wiping all grease off the bearings and out of the inside of the hub. Then washing the bearing in solvent - I use laquer thinner since I want it out quickly and I do so many, but mineral spirits work fine. Inspect the bearings and races carefully, grease them either in your hand by cutting the grease into the bearing or buy a inexpensive bearing grease cup and use that. Add a bit of grease to the outside of the bearing and reinstall the inner with a new double lip seal.
When you put the nut on, tighten and then back it out a flat or two so there is 1/16 inch or so of free play on the hub. THIS IS ESSENTIAL! As you go down the road your hubs get warm, as they get warm they expand and get tighter. You MUST have free play in your cold bearing or you will burn them up.
Bearing Buddies. On a boat, these are great. However, they play absolutely no part in greasing your bearings. What they do is add a little bit of grease pressure from the outside so when you back into the water, and cool off your hubs, which suddenly decreasies the pressure inside the hub, so that instead of pulling a drop of water in from the seal side, it pushes a drop of grease in from the Bearing Buddy side. The only purpose is to keep water out using grease pressure when the drop in temperature happens. It does that very well.
The proper way to use a Bearing Buddy is to take your grease gun with you to the ramp and pump just enough grease into the bearing buddy to visibly compress the spring just a smidgen so you know it has a little bit of pressure on it. Then back into the water confident your hubs won't pull any water in.
The wrong way to use a Bearing Buddy is to pump it up full at home and drive to the ramp. All you accomplish then is as you drive you pump the grease under pressure into the hub leaving the spring uncompressed, no protection from water entry as the hub cools, and eventually a full hub that spews grease all over everything.
These methods will work every time and everywhere. I would unscrew the zerk on a Dexter EZLube axle and replace with Bearing Buddies. And maintain them as part of your winterization.
Rick
MH Hawker
lololololol right.
UncleWillie
...Greasing by virtue of the Dexter EZLube zerk fills the hub up with grease and doesn't really grease the bearing until it is full. On any hub that has brakes this is a disaster as you will always end up getting grease into the brake shoes or pads when that full hub gets warm and the grease expands. That is nonsense. And who wants grease all over everything even if you don't have brakes to get gooey?
...The proper way to use a Bearing Buddy is to take your grease gun with you to the ramp and pump just enough grease into the bearing buddy to visibly compress the spring just a smidgen so you know it has a little bit of pressure on it. Then back into the water confident your hubs won't pull any water in.
The wrong way to use a Bearing Buddy is to pump it up full at home and drive to the ramp. All you accomplish then is as you drive you pump the grease under pressure into the hub leaving the spring uncompressed, no protection from water entry as the hub cools, and eventually a full hub that spews grease all over everything...
To rephrase the theory....
If you pump grease into the Bearing Buddy Hub at the ramp everytime you launch, and then later drive home pumping the grease under pressure into the Hub, you will eventually end up with the hub 100% full and Spewing Grease all over everything.
So either system produces the same end result! A Hub that is 100% full of Grease.
(I am not in agreement with this Theory. UW)
Rick Stephens
Not a theory. And you don't put in enough grease at the ramp to fill the hub up in a years time.
Either way, you are not greasing bearings by virtue of the bearing buddy or the EZLube until grease is spewing everywhere.
Rick
jkust
So last year the place that does my winterizing quoted $300 to repack my single axle trailer bearings. I see why people don't do it until they regret it.
With bearing Buddys, if you are using your grease gun at the ramp every time, you are going to have a blown rear seal. I have bearing buddys and fill the hub full and there is never a need to be adding grease over time once they are full.
MH Hawker
+1
If you keep adding grease to a BB it will soon blow the seals, the spring loaded cap is to allow for heat expansion nothing more.
MH Hawker
That is the very reason why the Dexter lube and others of the same type are in common use, it takes all of 30 minutes to repack both hubs.
