Just picked up a 2007 AZ259 Volvo 8.1
gotboostedvr6
We just picked up a freshwater used/ trailer stored 259. Its really a beautiful and well thought out boat.
Some questions I have already:
1.Where is the power inverter located? Looked everywhere.. 120v power does not currently work.
2. It has a noticeable lean Starboard sitting and on plane. We test drove several Azure boats and they all have this problem. Should i just expect its from wet foam or a design flaw?
thank you for looking
Would be kind of rare to have an inverter on a 25 footer.
Looked at on online and it has a Microwave and Fridge, but all that tells me is it would need to be plugged into shore power. Did not mention a Gen
The lean to starboard is about the same with all the small cruisers. Mine does it and it weights 10K lbs. It helps when I put water in the holding tank (on port side), but mostly just use trim tabs
gotboostedvr6
Boat in it's new parking spot and electric/ automatic Bennett trim tabs ordered.
fetch
