kad42a will not ran above 2000 rpm
muskrat
Is motor doesnt get alot of use,but a week ago ran for 4 hour with out a problem.All filter were changed in spring & were clean when dumped out.. Thanks
Re: kad42a will not ran above 2000 rpm
Make sure your getting full throttle at the pump. My understanding they have controls which need to be calibrated. Try this, Push the throttle full out, have a friend make sure the pump lever is moving full throttle. If it is not push it some more and if you get full throttle they need to be calibrated.
muskrat
Supercharger not ingauging.spins freely checked voltage 0.Where does it get its power from..
Sorrry it has taken me so long to get back, Iv'e been out of town. The super charger is belt driven, if it spins freely then your belt is probably broken. Hope it isn't the super charger
Volvo Penta Exploded view / schematic Compressor and Belt Protector with Installation Components KAD42A, KAMD42A - MarinePartsEurope.com
Turbo turns from engine exhaust gases
Volvo Penta Exploded view / schematic Turbo and Air Filter with Installation Components: B KAD42A - MarinePartsEurope.com
