kicker mounting
mossygo
I want to mount a kicker bracket for my boat, the motor will be a 7.5 2 stroke. I have a 20hp 2 stroke right now. Apparently the owner before the guy I bought the boat from had both motors mounted side by side which I have tried and it limits the steering way too much. Anyway, it's a 15 foot welded gregor, both motors are short shaft. I guess my first question is do you think mounting the kicker on a bracket would raise any concerns for my boat? The second is would you go with an adjustable or fixed bracket? I took a couple pictures, if different angles are needed let me know. Thanks
Re: kicker mounting
Ayuh,... It appears to me, you don't have enough Boat for 2 motors...
mossygo
Re: kicker mounting
kinda what I figured. Just a pain to swap motors depending on where I go since the 20 isn't the best troller in the world. I might just run another battery for the bow mount and troll with that.
