Knob on bottom fo steering column
jhogue46140
I have an 88 bass cat sabre with a mercury 150 xr4. There is a knob on the bottom of the steering column. What is its purpose. I have tried turning the knob but do not see any difference the the operation of the steering wheel. Thanks Doug
Re: Knob on bottom fo steering column
Ayuh,...
When you Tighten it, it should Stiffen the steering....
jhogue46140
Thanks. I'll try tightening again. I hadn't really messed with it but was curious what it was for. I didn't notice the steering wheel getting tighter when I tried before. Thanks Doug
204 Escape
Ensign
This is probably a dumb question, but if you pull the knob, does the steering wheel tilt ???? :confused:
jhogue46140
Hi 204,
No I tried that. I was hoping that was the case. It would give me more leg room. I have to leave the seat folded down to drive the boat. The boat has a hot foot. If I flip the seat back up I cant use the hot foot because my knees hit the steering wheel and console. Thanks for the comments. Doug
