leakdown/compression results
drem312
1999 twin bf130s.Had the recall done in 02 .This year before the sea trial had these test down and results are as follows
drem312
They are Hondas 130. Sea trialed Saturday boat ran perfect no issues performance wise that I could detect. Would sitting all winter and running the test affect thosr numbers? Tues the shop is running the test again after yesterdays run.
I would find another shop to repeat the test.------Wait , if they run good then use your coins for a case of beer.------?---# 2 bad on both engine seems hard to believe.
drem312
I cant wait to see the new numbers I know if the pistons arent perfect tdc things can be different I just dont like 200 psi #2 piston with that 34% number
gm280
Maybe some mental confusion on my part, but if your boat is running well, why do such tests? :noidea:
drem312
Not my boat yet did a sales agreememt these were the numbers their shop came up with when they checked the boat in
