Re: leaking rivets ?????
If you can Get to the rivet on the Inside you can re-buck it, and then coat it with some Gluvit. If you only have access from the outside you could use a Pop Rivet coat it with 3m 5200, pop it in, and then fill it and coat it with JB Weld.
