Leaking Trim Hydraulic Pump
Carl1783
Spotted this oily area around my trim pump today. Cannot tell where it seems to be leaking. Anyone ever dealt with this before?
Ayuh,..... My guess is, it's where the tank on the bottom, meets the pump in the center,.....
Carl1783
Thanks! Talked to the shop today (boat is in and having impeller and lower unit serviced) and he said parts are near impossible to find for one that old, and to just keep throwing paper towels at it. Thoughts from the iboats braintrust? Googling this issue seems to be an approach that lots of other guys take...
kenny nunez
The pump you have should not be that hard to repair. It is easy to remove from the boat and re seal it.
Ignore the lower post it is for the earlier style Prestolite pump.
