Leaky power steering ram. Replace or rebuild?
scooper77515
Volvo Penta 4.3L and the power steering ram has been leaking. I have shopped for replacements, but they go around $700. I keep coming across a rebuild kit.
Is the rebuild worth the hassle, or would I be better off in the long run by buying a new ram?
only you can answer is $45 and 1 hour of your time to reseal worth the $655 savings
scooper77515
Not a question of price, but a question of "Does the rebuild kit WORK?"
I have absolutely no problem with the price, or the amount of time. But I do not want to spend both to find that the rebuild kits don't work, or only work for half a season.
A rebuild kit is nothing more than seals / orings. Yes, that is usually what fails, is a seal or o-ring
scooper77515
Phenomenal help!!!
Thanks a bunch, dude!
Anyone else want to chime in on if they have had any luck with using a rebuild kit?
