Leaving block fully drained for winter
lenny2113
Good day all,<br />This is quick... <br />I remember reading a few posts that during winter time some people leave their block and manifolds dry without antifreeze/water mix.<br />Will this cause rust??? <br />Please share your observations and experience.<br />Thanks,
swansont
Re: Leaving block fully drained for winter
"pop" (sound of lid being blown off can of worms)<br /><br />Let the debates begin!<br /><br />Seriously Lenny, do a search on this and you will find many posts, believe me, in the short time I've been around this forum, I think this is the most argued subject. <br /><br />I leave mine dry, I've never seen a rusted out block, and air doesn't freeze.
I've been winterizing that way for All My Life,........<br /><br />My Mentors winterized that way All Their Lives,......<br /><br />I've Never,.... Ever seen a Rusted Out Engine Block,...........<br /><br />With the exception of an occasional motor that had Lived in Saltwater,....<br />And Then,.... It took Many Years of Saltwater exposure...........<br /><br />Cast Iron devolops a Rust Patina when exposed to water,....Almost Instantly....... <br />Once the surface has this patina,... It doesn't really continue Thru the block as fast,.....<br /><br />Manifolds,+ Risers are a different story,......<br />With the Constant Heat(up to 1200*),+ Water exposure,... They'll Rot Out Much Quicker........
KaGee
Air does not freeze, so you are protected. <br /><br />It seems that manifolds only last so long, no matter how you treat them. Here in fresh water, I have never heard of anyone's block rusting out. <br /><br />Maybe Bondo will post his thoughts. But I know he and several other "regulars" feel the same way. <br />*** nevermind, I see he was posting as I was typing :D
:D :D :D ;)
KaGee
Originally posted by swansont:<br /> "pop" (sound of lid being blown off can of worms)<br /><br />Let the debates begin!<br /><br />Seriously Lenny, do a search on this and you will find many posts, believe me, in the short time I've been around this forum, I think this is the most argued subject.
No way, it has to rate probably 3rd behind "auto vs. marine" and the #1 has to be the infamous "OIL" threads. ;) :D
I/O WALDO
"THE BOOK" says drain um!
lenny2113
"pop" (sound of lid being blown off can of worms)<br />Let the debates begin!<br />
:) Oops... That was not my intention... :) <br /><br />Guys, thanks for your time and efforts!!!<br /><br />Case closed ! :)
