Led trailer light issues...
gm280
Re: Led trailer light issues...
Oh yes the "GROUND" gremlin strikes again... However, folks also have to remember a few things as LEDs are taking over. They are LEDs, Light Emitting Diodes, and NOT regular lights bulbs with filaments in them that have zero polarity. LED Diodes do have a positive and negative connection. And because of that there will be more problems as more folks change over to them. An LED will only light if the polarity is observed. You simply can't connect them any way you wish and have them work properly. AND you certainly can't buy LEDs and simple connect 12 volts up to them or they will burn out near instantly for sure. Since they are polarity sensitive and only require a mere fraction of what filament bulbs require for current, you have to limit how much voltage you apply to them without current limiting resistors... Most LEDs take only a volt or two to allow them to work (light), and a very few milliamps as well. A standard taillight bulb (like the old 1157, 1257, etc.) takes 12 volts will an amp or more to light...see the problems...
All LED trailer lights have the current limiting resistor installed already so need to worry.
gm280
"bruceb58" you are absolutely correct on that. But if LED lights come with two wires out of the light module, you now have a polarity situation to deal with. You simply can't wire it anyway you like. So I think more issues with LEDs will be showing up on these forums...
Don Hansen
His issue is with the trailer/truck connection. No need to run seperate ground wires in fact this creates more problems down the road.
Why would this cause more problems down the road?
DLH
Because you now made everything twice as complicated. If one light doesn't work, you can concentrate on one light. When all the lights don't work, you don't know if its the new common ground you ran or the positive voltage to that particular circuit.
KISS principle!
Its so easy to attach a good ground at each light. Been doing it for over 30 years and have NEVER had a ground issue.
So I powered up some new LED clearance lights tonight that I just received. They actually work with either polarity. Looks like the circuit board of the light has a full wave rectifier on it.
So you can wire it up anyway you like.
