Life Expectancy of a Steel Fuel Tank
marvin the minnow
Just wondering how long these things last. I know it depends on the environment of the tank but im just curious if they all eventually rust out and leak.
robert graham
Re: Life Expectancy of a Steel Fuel Tank
Fresh water, painted, dry, probably last a very long time....salt water, not near as long.
marvin the minnow
my steel tank in my 77 Glastron CVX16 had rust holes in it but had also been sitting dry and corroded for a long time i suspect. I picked up another steel stank last night (the proce was right at $20) that is close to if not 10 years newer. there is just minor surface ruse at the edges ofthe tank and from what i can see inside looks good. tap test shows all signs of a solid tank.
Marvin, If you have an oil/gas fuel mix in the tank, and paint the outside with some Rustoleum Rusty Metal Primer, the tank can last a long time. Try to keep any water out of the tank.
Since I have not seen a steel tank in a long time, is it fair to say the tank is from the 70s?
Solittle
No leaks in my 122 gal tank so far - rig is 22 yrs old and I live in Miami & boat in the Keys.
Moody Blue
Not sure of the life expectancy but I'm hoping to get a few more years out of my 1971 Merc tank :D.
It's in great shape still, but the gauge is no longer readable.
