Limit Switch?
jasper astro
Does anyone know where I can locate a limit switch for a 1990 50 Hp Force?<br />It is located to the left of the carb along the side of the motor. Has a button in the middle of it, that is pressed in when the throttle is engaged in gear.<br />I may have found my problem with my motor, maybe.<br />jas,,,petey...
Re: Limit Switch?
Your Force does not have a rev limiter. <br />It does have a Neutral interlock switch, it is activated when in neutral, and allows the starter to engage. Has yellow wires , one connected to the starter relay, one to the ignition switch.<br /><br />If for some reason your motor is different, the place to get parts is a Mercury dealer.
jasper astro
Re: Limit Switch?
I guess taht would not have anything to do with my problem. Friend of mine says his on his 50 hp merc is whats causing his power loss. I just dont see how though. <br />Thanks roscoe,,,<br />jas....
