Liqua-Lube Bearings - any positive or negative info?
I'm considering going to the liqua-lube bearings after my left trailer tire seized up and sent my tire off the trailer while driving.<br />If that's ever happened to anyone else - you know you'll do anything and everything in your power to make **** sure it will never happen again.<br />- any positive or negative info?
Re: Liqua-Lube Bearings - any positive or negative info?
Full size trucks run front bearings in gear oil. I would just consider re-doing the bearings on both sides and using bearing buddies and grease. Everytime I go out I give my wheel bearings (and lower steering section of my outboard) a shot of grease.<br /><br />Examine your axel stubs very carefully and replace them too if needed. <br /><br />Bob
6MISFITZ
I agree with BOB_VT about doing both sides. <br />If one side went south on you on the highway, do both.<br />I purchased my boat and trailer late last July and considering the state of the bearings and seals when I did my spring inspection, I was lucky that I made the 500 km. tow home, not to mention the tows to launch / recover and home.<br />I spun the the drums after I pulled the wheels and could tell right away that I needed bearings and seals. <br />I followed directions and changed everything myself (wonderful job pressing out the 4 old races and installing new ones) and will be cleaning and repacking the bearings in the fall before storage. I have heard so much about bearing buddies and I will be investing in them when I can find them big enough for my hubs.<br />My drums are the big ones and the stores here carry the buddies for the 10 inch drums and smaller.
