Live well drains
ghollers
I bought a 90 285 Stratos and cannot for the life of me figure out how to drain the live wells. The manuel says there is a live well drain control which I cannot find. Can someone tell this knucklehead what to do?
Thanks,
G Hollers
cr2k
Re: Live well drains
Some are plugs inside the tanks. However there is no telling what the PO has done. if you can give him a call.
Hopefully someone with same boat will chime in.
Look in the restoration section and there is an iboats member restoring an even older stratos ....... he has some great pictures and you can see how his livewell lines are routed which might help!
Ayuh,... Crawl in there,+ Follow the Drain Lines to See what's up....
