Loctite on brake line fittings?
jacknbella
Should I use Loctite on my brake line connections or are they OK without it? If Loctite is recommended, which type is best?
Thanks in advance
Re: Loctite on brake line fittings?
Brake lines use "flared? interference seal. Using any type of a sealer on them may actually compromise the seal.
Proselect
No loctite, just snug down tight.
fishrdan
I wouldn't lock-tite them. They are hard enough to break loose without gluing them in, lock-tite them and it might be darn near impossible to remove without stripping.
Utahboatnut
They are hard enough to get apart if ever needed, loctite would render them useless if you needed to take them apart.
kenmyfam
Thanks in advance
No. Plain and simple.
