Long and short
cory13
Did Merc make a long and short shaft of the 84' 115 inline and if so , How long is each one. I think there was both a 20'' and a 25'' but not sure. Also this measurement is taken from the anticav plate to the ? . Thanks
Re: Long and short
Short shaft is a 15" length. Long shaft is 20". Merc made some shorties in the seventies, but I am not sure when they stopped making them. You might look on the Crowleymarine.com site and check all the models for the '84 model year.
Moody Blue
Re: Long and short
The lengths are measured from the anti-ventilation plate to the transom mount bracket where it sits on the transom.
A 20" shaft motor mounted on a boat with a 20" transom should place the anti-ventilation plate even with the bottom of the boat, approximately.
I think some of the smaller HP motors come in the 25" shaft size for use on sail boats as auxilliary motors.
