Long shaft to short shaft.
Texas_42
I have a 15' Duracraft and it now has long shaft 35 h.p. on it. I have a 35 short shaft that is in better shape and would like to put it on boat. Any ideas abt. cutting part out of transom to make motor fit..........thanks
Re: Long shaft to short shaft.
I wouldn't want to start cutting up the transom.<br />Are the motors the same, with interchangable parts?<br /><br />Why not take the better top half, and mate it up with the longshaft lower unit?
JB
Moving to General Outboard
one more cast
I used to have a '65 evinrude 35 short shaft and a '68 johnson 40 long shaft and I would switch the lower ends, drive shafts,and water tubes back and forth to see which motor worked better on which boat.
Texas_42
Duh.........I never thought of that. Sure is nice to have someone to look after us dummies......thanks for the advice
