Looking for 12 volts
Robbabob
Hey y'all, Installing the 3020 HD TV antenna, and need 12 vdc for the booster. I don't see a way to wire a new run to the panel, so I'm curious what options I have. Carver Montego 3257 1990 Found the radio wiring under the passenger seat, but can't get in there. Maybe remove the seat? Can I use the radio circuit for the booster? Thanks in advance!
not sure on your 3257, however I know on the 2557 there it was easy to run wires and cabling for a new Garmin 4210 with radar along with a new stereo, amp, and DVD player. we had to remove a bit of trim. however could run anything we needed then. you should be able to tie into the radio supply line, as the booster shouldnt take too much juice.
