looking for a duo prop
Status
Not open for further replies.
zell66
Need a B5 series prop # 854826 and #854834
Mod EDIT: please remember Iboats is a retailer, and carries props
You and I know you have to get an actual Volvo prop since there are no aftermarket versions of them. If you go on the iboats store you will therefore not see any there.
http://www.volvopentastore.com is through iBoats. Too bad the prices are horrible. You can see if they will match but doubtful.
You should also be looking at type J propellers. They have 4 blades on the rear prop. They are going to be the future replacement for the B props. If you need a complete set, go for the J props. Because of the shift to J props, you may have a lot less selection finding the B's.
http://www.volvopenta.com/SiteCollectionDocuments/Penta/Propeller guide/Propeller Guide.pdf
Look at page 20
zell66
What type of J prop should I be looking for to replace my B5 series?
My sugestion is to talk to a Volvo dealer. The J5 should be equivalent to a B5 as the pitch should be the same but that is just a guess. You should talk to someone who knows.
Maclin
Solas is producing B series Volvo DuoProp sets now since the Volvo patent ran out a few years ago.
That is good to know. Wonder if that's why Volvo brought out the J props.
If you go with a Solas, you will likely need to call Solas to see what a B5 corresponds to in inches of pitch since solas is available in 17", 19" and 21".
http://www.iboats.com/Boat-Parts-Acc...?q=8512-155-17
Maclin
According to my calcs with real world perfomance with my B5 set, a Solas 21" is closest to the B5. Their 23" is B6-B7 territory.
Maybe Volvo came out with the J series to counter their B and C series going into public domain.
Looks like they are only available in 17, 19 and 21 inch pitch
Maclin
I meant that I agree with you Bruce, that is almost certainly why Volvo came out with their new stuff.
Wonder when they will come out with versions of the newer Volvo drives. Mine uses F series.
Maclin
Yeah, just looked them up again, when they first came out there were more. They use to have B1-8 equivalents with varying combinations of the 17,19,21 and 23. Now just see the 21 at the top. A person should probably should call Solas to get the latest and greatest choices..
Maclin
I think the F and D have a few more years but just a feeling. The SX type drives were 95-96 origins? The B's and C's were back in mid 80's I think.
Maclin
I see where the Solas B/C 5's are their 19"on front and 21" on the back, and the B/C 6's are both 21" props. I may be remembering a hallucination or two about the Solas B7's and 8's ... :)
That can't be. They have to be identical pitch
You would think so, I always did and Volvos are, but take the *Select Size: drop down from this link...
Interesting! I was able to search and found the site you were trying to post.
Maclin
Cool.
Solas DuoProps pitches by set..:
B3's are 17/17
B4's are 19/19
B5's are 19/21
B6's are 21/21
Status
